GEFUNDEN Tausche Phobotic Centerpiece HV 3 Axis Brushless Gimbal Controller
tony
Tausche einen neuen Centerpiece HV Controller gegen preislich gleichwertigen Artikel.
Hier der Thread dazu.
Offizieller Preis 689€
  • Neu
    [*]Original verpackt
    [*]Komplett mit Zubehör
1x Centerpiece HV controller
2x Spectar IMU
2x Spectar IMU mounting hardware
2x IMU cable
This is the high-voltage Centerpiece, supporting input voltage up to 42v (10S) and supplied with two Spectar IMUs.
Specifications
▪ Supports high voltage, high current applications
▪ Completely auto tuning
▪ Dual/Triple processor architecture
▪ Robust CANBUS connectivity
▪ Accurate battery voltage compensation
Connectivity
▪ Bluetooth
▪ Futaba SBUS
▪ 4x PWM in/out + 4x PWM out
▪ Dual Spektrum satellites
▪ Dual IMU ports
▪ Phobotic expansion connector
Ratings
▪ Input voltage: 2S - 10S
▪ Current: up to 4A per motor
Dimensions
Outer dimensions: 69x63.5 (mm)
▪▪▪ Note that the PWM connector blocks protrudes another 8mm to the side
Mounting holes: 4 holes, 45x45 (mm) spacing, M3 bores
Spectar IMU outer dimensions: 23x23 (mm) square
Spectar IMU mounting holes: 4 holes, 18x18mm spacing, M2.5 bores
